(* Certified Functional (Co)programming with Isabelle/HOL *) (* Jasmin Christian Blanchette, Andreas Lochbihler, Andrei Popescu, Dmitriy Traytel *) section \Exercises on Coprogramming\ (* The exercises are at the end of this file. The start just defines some list and tree functions that were covered in the tutorial. *) theory Coprogramming_Sol imports "~~/src/HOL/Library/BNF_Corec" begin subsection \Lazy lists\ codatatype 'a llist = lnull: LNil | LCons (lhd: 'a) (ltl: "'a llist") for map: lmap where "ltl LNil = LNil" lemma LCons_lazy: "x = y \ LCons x xs = LCons y xs" by simp setup {* Code_Simp.map_ss (Simplifier.add_cong @{thm LCons_lazy}) *} subsection \Trees\ codatatype 'a tree = is_Leaf: Leaf | Node (left: "'a tree") (val: 'a) (right: "'a tree") for map: tmap where "left Leaf = Leaf" | "right Leaf = Leaf" lemma Node_lazy: "x = y \ Node l x r = Node l y r" by simp (* Lazy symbolic evaluation with value [simp] (odd style with ease) *) setup {* Code_Simp.map_ss (Simplifier.add_cong @{thm Node_lazy}) *} lemma tmap_sel [simp]: "left (tmap f t) = tmap f (left t)" "right (tmap f t) = tmap f (right t)" "\ is_Leaf t \ val (tmap f t) = f (val t)" by(cases t; simp; fail)+ primcorec chop :: "'a tree \ 'a tree" where "is_Leaf t \ is_Leaf (left t) \ is_Leaf (right t) \ is_Leaf (chop t)" | "val (chop t) = (if is_Leaf (left t) then val (right t) else val (left t))" | "left (chop t) = (if is_Leaf (left t) then left (right t) else right t)" | "right (chop t) = (if is_Leaf (left t) then right (right t) else chop (left t))" lemma chop_match [simp]: "chop Leaf = Leaf" "chop (Node l x r) = (if is_Leaf l then r else Node r (val l) (chop l))" by(rule tree.expand; simp; fail)+ subsection \From lists to trees and back\ primcorec tree_of :: "'a llist \ 'a tree" where "lnull xs \ is_Leaf (tree_of xs)" | "left (tree_of xs) = Leaf" | "val (tree_of xs) = lhd xs" | "right (tree_of xs) = tree_of (ltl xs)" lemma tree_of_match [simp]: "tree_of LNil = Leaf" "tree_of (LCons x xs) = Node Leaf x (tree_of xs)" by(rule tree.expand; simp; fail)+ primcorec llist_of :: "'a tree \ 'a llist" where "is_Leaf t \ lnull (llist_of t)" | "lhd (llist_of t) = val t" | "ltl (llist_of t) = llist_of (chop t)" lemma llist_of_match [simp]: "llist_of Leaf = LNil" "llist_of (Node l x r) = LCons x (llist_of (chop (Node l x r)))" by(rule llist.expand; simp; fail)+ lemma chop_tree_of: "chop (tree_of xs) = tree_of (ltl xs)" apply(cases xs) apply simp_all done lemma llist_of_tree_of: "llist_of (tree_of xs) = xs" apply(coinduction arbitrary: xs) apply(simp_all add: chop_tree_of) done section \Exercises\ subsection \Another conversion to trees\ (* Define a function tree_of' :: "'a llist \ 'a tree" that converts a lazy list [x,y,z,...] into a tree that leans to the left, i.e., x / \ y Leaf / \ z Leaf ... *) primcorec tree_of' :: "'a llist \ 'a tree" where "lnull xs \ is_Leaf (tree_of' xs)" | "val (tree_of' xs) = lhd xs" | "left (tree_of' xs) = tree_of' (ltl xs)" | "right (tree_of' xs) = Leaf" (* Prove that tree_of' is a right-inverse of llist_of. Hint: You might need a lemma about chop and tree_of'. You can use value with finite lazy lists to see what chop does to tree_of'. *) lemma chop_tree_of': "chop (tree_of' xs) = (if lnull xs then Leaf else tree_of (ltl xs))" apply(coinduction arbitrary: xs rule: tree.coinduct_strong) apply auto done lemma llist_of_tree_of' [simp]: "llist_of (tree_of' xs) = xs" apply(rule llist.expand) apply(simp_all add: chop_tree_of' llist_of_tree_of) done subsection \Ascending numbers\ (* Define a function lup :: int llist that is the list of all non-negative integers in ascending order. Hint: Use corecursion up-to. *) friend_of_corec lmap :: "('a \ 'a) \ 'a llist \ 'a llist" where "lmap f xs = (case xs of LNil \ LNil | LCons x xs \ LCons (f x) (lmap f xs))" by(rule llist.expand; simp split: llist.split) transfer_prover corec lup :: "int llist" where "lup = LCons 0 (lmap (op + 1) lup)" subsection \A tree of all non-negative numbers\ (* Define a tree tnum :: int tree with no Leafs such that llist_of is the ascending list of numbers (use int as element type). Prove the lemma. Hint: You will need to prove lemmas about how the friends interact with your functions. *) friend_of_corec tmap :: "('a \ 'a) \ 'a tree \ 'a tree" where "tmap f t = (case t of Leaf \ Leaf | Node l x r \ Node (tmap f l) (f x) (tmap f r))" by(rule tree.expand; simp split: tree.splits) transfer_prover corec tnum :: "int tree" where "tnum = Node (tmap (\x. x * 2 + 1) tnum) 0 (tmap (\x. x * 2 + 2) tnum)" lemma tnum_sel [simp]: "is_Leaf tnum = False" "val tnum = 0" "left tnum = tmap (\x. x * 2 + 1) tnum" "right tnum = tmap (\x. x * 2 + 2) tnum" by(subst tnum.code; simp; fail)+ lemma chop_tmap: "chop (tmap f t) = tmap f (chop t)" apply(coinduction arbitrary: t rule: tree.coinduct_strong) apply(auto simp add: tree.map_sel) done lemma chop_tnum: "chop tnum = tmap (op + 1) tnum" proof(coinduction rule: tnum.coinduct) case Eq_int_tree have "?is_Leaf" by simp moreover have "?Node" proof(intro strip conjI) let ?R = "\t t'. t = chop tnum \ t' = tmap (op + 1) tnum" show "tree.congclp ?R (left (chop tnum)) (left (tmap (op + 1) tnum))" by(simp add: tree.map_comp o_def algebra_simps tmap.friend.cong_refl) show "val (chop tnum) = val (tmap (op + 1) tnum)" by simp have "right (tmap (op + 1) tnum) = tmap (\x. x * 2 + 1) (tmap (op + 1) tnum)" by(simp add: tree.map_comp o_def) then show "tree.congclp ?R (right (chop tnum)) (right (tmap (op + 1) tnum))" by(simp add: chop_tmap tmap.friend.cong_tmap[OF refl] tmap.friend.cong_base) qed ultimately show ?case by simp qed lemma llist_of_tmap: "llist_of (tmap f t) = lmap f (llist_of t)" apply(coinduction arbitrary: t) apply(auto simp add: llist.map_sel chop_tmap) done lemma llist_of_tnum: "llist_of tnum = lup" apply(rule lup.unique) apply(rule llist.expand) apply(simp_all add: chop_tnum llist_of_tmap) done end
